Differences
Link to this comparison view
Next revision
Previous revision
cms:units:aliases [06/09/2019 15:36]
alse [Command Properties]
cms:units:aliases [04/11/2019 16:44] (current)
mary [Commands for flespi devices]
Line 4: Line 4:
 :!:  To work with commands, the //View commands// and //Create, edit, and delete commands// access rights are required. :!:  To work with commands, the //View commands// and //Create, edit, and delete commands// access rights are required.
-On the //​Commands//​ tab in the [[units#unit_properties_dialogue|unit properties dialog]], you can create and configure commands to be sent to the unit. A command can be sent manually from the monitoring panel and automatically by means of [[user/​jobs/​jobs|jobs]] and [[user/​notify/​notify|notifications]]. If you want a command that was sent automatically to be executed by several units at once, make sure that it has the same name in the properties dialogs of these units.+On the //​Commands//​ tab in the [[units#unit_properties_dialog|unit properties dialog]], you can create and configure commands to be sent to the unit. A command can be sent manually from the monitoring panel and automatically by means of [[user/​jobs/​jobs|jobs]] and [[user/​notify/​notify|notifications]]. If you want a command that was sent automatically to be executed by several units at once, make sure that it has the same name in the properties dialogs of these units.
 {{ :​units:​cmd1.png?​nolink }} {{ :​units:​cmd1.png?​nolink }}
Line 46: Line 46:
 For details on sending the commands, see //​[[user/​monitor/​cmd|Commands]]//​. For details on sending the commands, see //​[[user/​monitor/​cmd|Commands]]//​.
-===== Creating commands ​for flespi devices =====+===== Commands ​for flespi devices =====
-For [[https://​flespi.com/​protocols#​devices|flespi ​devices]], a form for creating custom commands is availableTo configure ​a command, ​follow these steps:+A set of commands available for a [[https://​flespi.com/​protocols#​devices|flespi ​device]] depends on its typeWhen creating ​a command, ​you can configure its parameters. To do this, deactivate the //Without parameters//​ option ​ and click on the //​Configure//​ button. Next, enter the necessary parameters and click //Apply//.
-  - Specify ​the name and select the type of the command in its configuration dialog. The list of supported commands depends on the [[https://flespi.com/​protocols#protocols|protocol]] used by the device and is constantly expanding+If the //Without parameters//​ option is activated, you should indicate ​the parameters every time before ​[[user/monitor/cmd#sending_and_tracking_commands|sending]] the command
-  - Select the channel. The //Virtual// channel is used to send commands to flespi devices+
-  - Specify the other properties of the command. +For more information about how to send commands ​from Wialon ​to flespi devices, follow this [[https://gurtam.com/hw/files/commands%20flespi_EN.pdf|link]].
-  - Deactivate the //Without parameters//​ option and click on the //​Configure//​ buttonIn the window that opens next, type the text of the command and click //Apply//. +
-The created command is added to the list of commands in the unit properties, after which you can [[user/​monitor/​cmd|send]] it to the device. +
