Differences
Link to this comparison view
cms:port:set [30/05/2019 17:49]
mary [User Settings Transfer] zark
cms:port:set [09/09/2019 11:58] (current)
tagr
Line 4: Line 4:
 Individual settings can be transferred from one user to others or stored in a file.  Individual settings can be transferred from one user to others or stored in a file.
-You can import data from the //​[[user/​set/​set|User Settings]]//​ dialog, //​Settings//,​ //Maps// tabs, and //​Monitoring//​ panel. To do so, you should have the //Edit not mentioned properties//​ [[../​rights/​user|access]] to a user you import the data to. Most of [[cms/​users/​props|User Properties]] can be imported, too (the tabs //​General//,​ //​Advanced//,​ //Custom Fields//). To import them, you should have the //Change flags for given user//, //Edit not mentioned properties//,​ and //Manage custom/​admin fields// access rights, accordingly. Such unique settings as e-mail, password, account information,​ access rights, etc. cannot be transferred.+You can import data from the //​[[user/​set/​set|User Settings]]//​ dialog, //​Settings//,​ //Maps// tabs, and //​Monitoring//​ panel. To do so, you should have the //Edit not mentioned properties//​ [[../​rights/​user|access]] to a user you import the data to. Most of [[cms/​users/​props|User Properties]] can be imported, too (the tabs //​General//,​ //​Advanced//,​ //Custom Fields//). To import them, you should have the //Change flags for given user//, //Edit not mentioned properties//,​ and //Manage custom/​admin fields// access rights, accordingly. Such unique settings as email, password, account information,​ access rights, etc. cannot be transferred.
 Here is the list of settings that can be chosen for import/​export: ​ Here is the list of settings that can be chosen for import/​export: ​
