Differences
Link to this comparison view
cms:port:res [12/12/2017 12:37]
tagr [Resource Contents Transfer]
cms:port:res [25/09/2018 10:04] (current)
tagr
Line 22: Line 22:
 If the report template contains parameters to filter intervals by geofences, these parameters should be checked (and probably corrected) when the template is copied to another resource as geofences can be bind to a template only within the same resource. Also, connection with units can be lost because the new owner of the template does not have enough access to the units. ​ If the report template contains parameters to filter intervals by geofences, these parameters should be checked (and probably corrected) when the template is copied to another resource as geofences can be bind to a template only within the same resource. Also, connection with units can be lost because the new owner of the template does not have enough access to the units. ​
-The same is true for jobs and notifications if they mention geofences, units, users, reports, groups etc.since the new //owner// of a notification/​task must have access rights to work with these objects.+The same is true for jobs and notifications if they mention geofences, units, users, reports, groups etc. since the new //owner// of a notification/​task must have access rights to work with these objects.
