Differences
Link to this comparison view
cms:port:port [11/12/2017 16:55]
tagr [Required Access]
cms:port:port [11/12/2017 16:56] (current)
Line 26: Line 26:
 [[cms/​rights/​rights|Access rights]] are important for import/​export. Keep in mind two simple rules: ​ [[cms/​rights/​rights|Access rights]] are important for import/​export. Keep in mind two simple rules: ​
-  - You can export from an object only those properties or contents that are available to you (you should have at least //​View ​access// to these properties in the initial object). ​+  - You can export from an object only those properties or contents that are available to you (you should have at least view access to these properties in the initial object). ​
   - You can import into an object only those properties or contents that are editable for you (you need the //Create, edit, delete// access to these properties in the destination object). ​   - You can import into an object only those properties or contents that are editable for you (you need the //Create, edit, delete// access to these properties in the destination object). ​
