Differences
Link to this comparison view
cms:port:exp-kml [12/12/2017 10:46]
tagr [Export to KML/KMZ]
cms:port:exp-kml [25/09/2018 10:03] (current)
tagr
Line 4: Line 4:
 This option allows you to [[port|export]] geofences from all available resources to a file.  This option allows you to [[port|export]] geofences from all available resources to a file.
-When you export to KML/KMZ, the list of all available geofences (depending on the item type chosen) is displayed. Check the items you want to export and press //OK//. Optionally, you can enter a file name and compress file as KMZ. After that, press //OK// and save the file.+When you export to KML/KMZ, the list of all available geofences (depending on the item type chosen) is displayed. Check the items you want to export and press //OK//. Optionally, you can enter a file name and compress ​the file as KMZ. After that, press //OK// and save the file.
 {{ :​port:​exp-kml.png?​nolink }} {{ :​port:​exp-kml.png?​nolink }}
