Differences
Link to this comparison view
Next revision
Previous revision
cms:gui:set [28/05/2018 08:40]
tagr [CMS Settings]
cms:gui:set [14/12/2018 13:24] (current)
tagr beta
Line 5: Line 5:
 The //User settings// dialog contains two tabs:  The //User settings// dialog contains two tabs:
-  - **General settings** — here you can indicate your time zone, e-mail, change password, etc. +  - **General settings** — here you can indicate your time zone, e-mail, change ​the password, etc.
   - **Security** — on this tab you can configure authorization settings, activate two-factor authentication and set an e-mail notification about account blocking.   - **Security** — on this tab you can configure authorization settings, activate two-factor authentication and set an e-mail notification about account blocking.
   - **Account** — here you can view your billing plan, account balance, available and used services, etc.    - **Account** — here you can view your billing plan, account balance, available and used services, etc.
-In addition, for the top-level user, the //​Branches//​ tab is available. This tab allows you to select the branches for the existing DNS user:+<​html><​!--:​!:​In addition, for the top-level user, the //​Branches//​ tab is available. This tab allows you to select the branches for the existing DNS user:
   * **Stable** — a stable branch, rarely updated.   * **Stable** — a stable branch, rarely updated.
   * **Beta** — a branch containing the latest updates introduced into the monitoring system. It is intended for the analysis of Wialon updates.   * **Beta** — a branch containing the latest updates introduced into the monitoring system. It is intended for the analysis of Wialon updates.
-  * **Stable/​Beta** — this option allows users who are working with this DNS to switch between branches when they log on to the monitoring system. ​+  * **Stable/​Beta** — this option allows users who are working with this DNS to switch between branches when they log on to the monitoring system.--></​html> ​
 {{ :​cms:​set1.png?​nolink }} {{ :​cms:​set1.png?​nolink }}
