Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
cms:accounts:transfer [16/03/2018 11:32]
irra https://webmail.gurtam.net/profiles/ticket/TWA-46587-331
cms:accounts:transfer [21/09/2018 15:56]
tagr
Line 4: Line 4:
 :!: The //Units// service must be activated for the account to which a unit is transferred. ​ :!: The //Units// service must be activated for the account to which a unit is transferred. ​
-You can transfer units from the currently used account to the subordinate ones or between the subordinate ones. The account should possess the dealer rights in order for the feature to be available . +You can transfer units from the currently used account to the subordinate ones or between the subordinate ones. The account should possess the dealer rights in order for the feature to be available. ​
 The following access rights towards a unit are required to transfer it from one account into another: ​ The following access rights towards a unit are required to transfer it from one account into another: ​
Line 13: Line 13:
   * Delete messages.   * Delete messages.
-Moreover, it is necessary to possess the //View item and its basic properties//​ right towards the creator of the unit and //Act as given user// towards the creator of the account you want to transfer the units to. The latter, in turn, must have the right to view the item and their properties towards the units from the left list of the dialog of switching account. ​+Moreover, it is necessary to possess the //View item and its basic properties//​ right towards the creator of the unit and //Act as given user// towards the creator of the account you want to transfer the units to. The latter, in turn, must have the right to view the item and their properties towards the units from the right list of the dialog of switching account. ​
 The units are transferred in the management interface. To begin with, open the //Units// tab. Then click on the //Switch account// button {{:​icons:​account_move.png?​nolink}} (unavailable if the account does not have the dealer rights) located to the right of the //Delete selected items// button. ​ The units are transferred in the management interface. To begin with, open the //Units// tab. Then click on the //Switch account// button {{:​icons:​account_move.png?​nolink}} (unavailable if the account does not have the dealer rights) located to the right of the //Delete selected items// button. ​
