Differences
Link to this comparison view
Next revision
Previous revision
cms:accounts:services [09/09/2019 11:50]
tagr
cms:accounts:services [03/02/2020 18:46] (current)
alse
Line 7: Line 7:
 | **Admin fields** |Allows to create admin fields in the properties of the unit, user or group (on the //Custom Fields// tab); defines the available quantity (in total) and the cost of such fields. | | **Admin fields** |Allows to create admin fields in the properties of the unit, user or group (on the //Custom Fields// tab); defines the available quantity (in total) and the cost of such fields. |
 | **Advanced reports** | Allows to use advanced reports, i.e., reports by unit groups, users, drivers, trailers, as well as groups of drivers and trailers (except for the //Log// table for users and unit groups). Works within Reports module. | | **Advanced reports** | Allows to use advanced reports, i.e., reports by unit groups, users, drivers, trailers, as well as groups of drivers and trailers (except for the //Log// table for users and unit groups). Works within Reports module. |
 +| **App for iOS and Android** | Activates access to the [[https://​mobileapp.wialon.com/​android/​en/​Default.htm|application for iOS and Android]]. |
 | **Commands** | Activates the corresponding tab in the //Unit Properties//​ dialog; defines the quantity (total for all units) and cost of commands. | | **Commands** | Activates the corresponding tab in the //Unit Properties//​ dialog; defines the quantity (total for all units) and cost of commands. |
 | **Create resources** | Activates the button to create resources and accounts on the corresponding panel (available only in CMS Manager). | | **Create resources** | Activates the button to create resources and accounts on the corresponding panel (available only in CMS Manager). |
Line 13: Line 14:
 | **Create users** | Activates the button to create users in the corresponding panel. | | **Create users** | Activates the button to create users in the corresponding panel. |
 | **Custom fields** | Activates the corresponding tab in the properties of the unit, user or group; defines cost and quantity (in total) of custom fields; does not affect drivers and trailers. | | **Custom fields** | Activates the corresponding tab in the properties of the unit, user or group; defines cost and quantity (in total) of custom fields; does not affect drivers and trailers. |
-| **Drivers** | Activates Drivers module and defines cost and quantity of drivers; if disabled, the Drivers panel is not shown, and any mentioning of drivers disappears from notifications,​ user settings, and //SMS// dialog. | +| **Dashboard** | Activates the //​[[user/​monitor/​dashboard|Dashboard]]//​ page. |
-| **Еmail notifications** | Allows to send notifications by email. ​Recommended limitation — 10 reports ​per hour (not to overload the server). | +| **Drivers** | Activates ​the Drivers module and defines cost and quantity of drivers; if disabled, the Drivers panel is not shown, and any mentioning of drivers disappears from notifications,​ user settings, and //SMS// dialog. |
-| **Еmail reports** | Allows to send a report ​by email (within ​the Jobs module)Recommended limitation — 10 reports per hour (to avoid server ​overload). |+| **Еmail notifications** | Allows to send notifications by email. ​The service limit depends on the number of purchased licences. We recommend sending no more than 10 notifications ​per hour so as not to overload the server. |
 +| **Еmail reports** | Allows to send reports ​by email. The service limit depends on the number of purchased licencesWe recommend sending no more than 10 reports per hour so as not to overload ​the server. |
 | **Eco driving** | Activates Eco Driving tab in the //Unit properties//​ dialog, as well as the same-name table in reports. Besides, Eco driving app does not work without this service. | | **Eco driving** | Activates Eco Driving tab in the //Unit properties//​ dialog, as well as the same-name table in reports. Besides, Eco driving app does not work without this service. |
-| **Fleetrun** | Activates access to the [[http://​apps.wialon.com/?​lang=en#​fleetrun|Fleetrun]] ​app. |+| **Fleetrun** | Activates access to the [[http://​apps.wialon.com/?​lang=en#​fleetrun|Fleetrun]] ​application. |
 | **Geofences** | Activates the //​Geofences//​ module and defines the cost and quantity of geofences; if disabled, the //​Geofences//​ panel is not shown, and any mention of geofences disappears from reports and user settings. | | **Geofences** | Activates the //​Geofences//​ module and defines the cost and quantity of geofences; if disabled, the //​Geofences//​ panel is not shown, and any mention of geofences disappears from reports and user settings. |
 | **Google (custom)** | Allows to regulate access to the Google maps, geocoding, and routing for the lower-level accounts. This service works with the key provided by the user. | | **Google (custom)** | Allows to regulate access to the Google maps, geocoding, and routing for the lower-level accounts. This service works with the key provided by the user. |
Line 26: Line 28:
 | **Groups of\\ trailers** | Defines the available quantity and cost of trailer groups; works within the //​Trailers//​ module. | | **Groups of\\ trailers** | Defines the available quantity and cost of trailer groups; works within the //​Trailers//​ module. |
 | **Groups of\\ passengers** | Defines the quantity and cost of passenger groups; works within the //​Passengers//​ module. | | **Groups of\\ passengers** | Defines the quantity and cost of passenger groups; works within the //​Passengers//​ module. |
 +| **Hecterra** | Activates access to the [[https://​hecterra.wialon.com/​|Hecterra]] application. |
 | **Import/​Export** | Enables access to the dialogs of import/​export in the user menu; activates the //Create from WLP// button in the //Units// panel and the //Export in file// button in the unit properties dialog. | | **Import/​Export** | Enables access to the dialogs of import/​export in the user menu; activates the //Create from WLP// button in the //Units// panel and the //Export in file// button in the unit properties dialog. |
 | **Jobs** | Activates the //Jobs// panel and defines the available quantity and cost of jobs. | | **Jobs** | Activates the //Jobs// panel and defines the available quantity and cost of jobs. |
Line 33: Line 36:
 | **Messages** | Access to the //​Messages//​ panel. | | **Messages** | Access to the //​Messages//​ panel. |
 | **MGRS** | The service allows to activate the MGRS grid for Gurtam Maps. | | **MGRS** | The service allows to activate the MGRS grid for Gurtam Maps. |
-| **Mobile client** | Activates access to [[:​mobile/​mobile0/​mobile0|Wialon mobile client]]. |
 | **Mobile notifications** | Activates the corresponding action in notifications,​ as well as the tab in the //Manage Applications//​ dialog (in user menu). | | **Mobile notifications** | Activates the corresponding action in notifications,​ as well as the tab in the //Manage Applications//​ dialog (in user menu). |
-| **NimBus** | Activates access to the [[http://​apps.wialon.com/?​lang=en#​nimbus|NimBus]] ​app. |+| **NimBus** | Activates access to the [[http://​apps.wialon.com/?​lang=en#​nimbus|NimBus]] ​application. |
 | **Notices to\\ users** | Allows to receive notices from the administrator of the service. | | **Notices to\\ users** | Allows to receive notices from the administrator of the service. |
 | **Notifications** | Activates the //​Notifications//​ panel and defines the cost and allowed quantity of notifications. | | **Notifications** | Activates the //​Notifications//​ panel and defines the cost and allowed quantity of notifications. |
Line 60: Line 62:
 | **Users** | Activates the corresponding panel and defines the cost and quantity of users. | | **Users** | Activates the corresponding panel and defines the cost and quantity of users. |
 | **Video** | Activates the [[user/​monitor/​minimap#​minimap_modes|video surveillance]] mode. | | **Video** | Activates the [[user/​monitor/​minimap#​minimap_modes|video surveillance]] mode. |
-| **Wialon Mobile (2)** | Allows ​to track units from a mobile ​phone (Wialon Mobile v2).\\ :!: If mobile service URL is different from //​m.wialon.com//,​ it can be disabled only through the //Site access// feature. |+| **Wialon Mobile (2)** | Access ​to [[https://​docs.wialon.com/​en/​hosting/​mobile/​mobile2/​mobile2|Wialon Mobile v2]]. :!: If mobile service URL is different from //​m.wialon.com//,​ it can be disabled only through the //Site access// feature. |
 | **Yandex (custom) ** | Allows to regulate access to the Yandex maps, geocoding, and routing for the lower-level accounts. This service works with the key provided by the user. | | **Yandex (custom) ** | Allows to regulate access to the Yandex maps, geocoding, and routing for the lower-level accounts. This service works with the key provided by the user. |
 | **Yandex (standard) ** | Allows to regulate access to the Yandex maps for the lower-level accounts. This service works with the key purchased from Gurtam. The following expansions are available to users: //​extensions//​ (activates geocoding and routing services) and //​panorama//​ (activates panorama services). | | **Yandex (standard) ** | Allows to regulate access to the Yandex maps for the lower-level accounts. This service works with the key purchased from Gurtam. The following expansions are available to users: //​extensions//​ (activates geocoding and routing services) and //​panorama//​ (activates panorama services). |
Line 67: Line 69:
 | **Yandex (standard) —\\ routing** | Activates the possibility of building routes by Yandex Maps for the //​[[user/​tools/​routing|Routing]]//​ tool. | | **Yandex (standard) —\\ routing** | Activates the possibility of building routes by Yandex Maps for the //​[[user/​tools/​routing|Routing]]//​ tool. |
-:!: //Note//.\\ If you see //Apps// in front of a service name, it means this service is an [[../​apps/​apps|application]].
